Pspice for C3M0045065D
I downloaded the C3M0045065D SPICE model for simulating in PSpice. I have a question I am confused about:
- There is not only one PSpice model in the PSpice model editor after opening it.
- I tried to import the model using the wizard and simulate it, but the simulation failed.It seems the subcircuit is undefined
My question is: how can I solve this issue?
There was a small issue with the model (in one of the .ends command) that have been fixed and attached here. I have also attached the forward characteristics (at Tj = 25C) test results below. To answer your first question, just use the C3M0045065D model and all the other subcircuits (CDSMOS_C3M0045065D, CGDMOS_C3M0045065D and GMOS_C3M0045065D) are called by the subcircuit C3M0045065D.
Let us know if you need further assistance.
Regards
Hi Ethan,
I apologize for the late reply. Here are the simulation files for the output characteristics test bench. Let us know if you need further assistance.
Regards
1
