CRD300DA12E: Power Output vs Switching Frequency
Hello all,
For a project that I am currently working on, I am using the off-the-shelf CRD300DA12E-XM3 inverter.
I see that on the datasheet of the power modules used in this invergter there is a graph describing the relationship between the output current and switching frequency of the modules, however, I would also be interested to have a graph specifically describing the output power of the inverter with respect to the switching frequency of the power modules.
Is this infomarion available somewhere?
Looking forward to hearing from you.
Thank you in advance,
Konstandin Kotsis
Hi Konstandin,
Please reference the following post, I believe the curve you are looking for can be found here along with further information.
Jonathan
Hello Jonathan,
The post actually helped.
Thank you
