Mechanism of threshold voltage in the model
Yangtze
Yangtze Contributor Level 1
edited August 2024 in Discrete Products
Well, does anyone knows which parameter represents the threshold voltage in this model? Is it named as NET3, first appeared in line 60? How can I modify the value of threshold voltage?
  • Mhusain
    Yes, the equation on line 60 of this model is designed to simulate how the threshold voltage varies with temperature. While you can modify this equation to adjust the threshold voltage, doing so may impact the overall performance of the model, so it's not recommended.
    Regards
    Hi, I hope that this answered your question. I will close this discussion for now but if you have a follow up question, please "Start a New Discussion" and we would be glad to support you further
