Rogowski coil current probe deskewing
Hi Wolfspeed team,
In the document PRD-08333 "Wolfspeed Module CIL Evaluation Kits User Guide", I found that Wolfspeed uses in-house deskew compensation PCB that allows all probes to be connected equidistant from waveform generator.
Does Wolfspeed have any recommendations to deskew Rogowski coil current probe, or is there any third party tool you verified in the past? Thank you for your support.
Hiroshi
Hi Hiroshi-san,
For Rogowski current probe de-skew, we have utilized the de-skew fixture board: Tektronix 067-1686-00.
It is also possible to de-skew against another current signal such as the current viewing resistor (CVR) on Wolfspeed's evaluation kits.
Hi Austin,
Thank you so much for the answer!
Hiroshi
