Request for CRD60DD12N-GMB Controller Firmware
SANATH_IRIS
SANATH_IRIS Contributor Level 2
edited April 2025 in Module Products
We are working on building the proto board based on CRD60DD12N-GMB
I would request you to share the Controller firmware.
Regards
Sanath
    Ruson
  • Ruson
    Ruson Contributor Level 1
    SANATH_IRIS
  • USER_KE
    USER_KE Contributor Level 1
    We are working on building the proto board based on CRD-22AD12N
  • USER_KE
    We are also working on building the proto board based on CRD-22DD12N-J2
    I would request you to share the Controller firmware to reference
    thanks
    edited March 2025
    Hello Sanath and Ruson,
    Regarding the CRD60DD12N-GMB firmware, due to the higher complexity of the firmware compared to our inverter reference designs, we are not publicly sharing the firmware at this time. The reference design can still be used as a hardware starting point and for identifying best practices for SiC power module layout.
    For the CRD-22AD12N and CRD-22DD12N-J2 designs, please use the "Request Firmware" button on each of these respective designs in order to obtain the firmware.
  • Ruson
    edited April 2025
    Hello, ChrisN
    I requested Firmware form  CRD-22AD12N and CRD-22DD12N-J2 designs, but no response.
    Please help to check it.
    Ruson
    Hello Ruson,
    Unfortunately, I am not in charge of handling firmware requests for those designs. The requests typically take a few days to process, so I anticipate that you will receive the requested files soon.
    Hello Ruson and USER_KE,
    We have received multiple firmware requests from you for various different designs. I understand you're interested in the firmware for  CRD-22AD12N and CRD-22DD12N-J2 for which I have informed my Sales team and they're going to contact you to understand your project better. Thank you!
    I will close this discussion for now but if you have a follow up question, please "Start a New Discussion" and we would be glad to support you further.
