Rogowski Coil
Hasan
Hasan Contributor Level 1
I'm currently in the process of assembling the board and couldn't find the rogowski coil specs. Are there any recommendations for the coil?
Additionally, are there any SPICE libraries/models for the components used in building the circuit?
Thanks for your support.
  • FrankWei
    FrankWei Wolfspeed Employee - Contributor Level 2
    Hello Hason,
    Could you please point out the specs or requirements for the board you are working for?
    Additionally, which component are you using now? any Part numbers
    Regards.
    Frank
  • Hasan
    Hi Frank,
    I am rebuilding CRD-22DD12N board following the bom provided by Wolfspeed for that design. I am purchasing the same components for the most part if they are in stock.
    I currently have most of the parts and was wondering about the Rogowski coils design since I did not see any references for the used coil in the design docs provided by Wolfspeed.
    Thanks.
  • FrankWei
    Hi Hason,
    I assume that you are looking for the current transformers on the power transformers. they are 200:1 CTs.
    For the simulation model of C3M0032120K, you can download it from our website.
    Frank
  • Hasan
