Gate driver IC for high power industrial application
we are developing a multi-level DC-DC converter for high power industrial application.
Input - 1.5 to 2.8kV
output- .950 to 1.45kV
. We want your suggestions for selecting the isolated gate driver IC that meets our requirements. Gate driver IC clearance should be 15.4mm.
Hello DV_s,
Sure, a member of our technical team is looking into your question. Can you tell me about which MOSFETs you're using? Thanks!
We are using 2.3kV Sic MOSFET
Can you please share the Part Number?
we are planning to use CAB5R0A23GM4. For the gate driver we required 13kVpeak impulse isolation voltage (Reinforced isolation). Can you please suggest any solution for this isolation requirement.
