3d model for controller board v1.2
the CAD files for the CRD300DA12E-XM3 seem to show an updated or different version regarding the main control-board. Our CAD-program calls it "X18-Controller-V1-8" and the board-revision we have is V1.2. The main differences found so far are the following:
- missing mounting holes on the bottom corner (between J1/J2 andJ2/J3)
- fan connectors J12 and J13 are rotated
- LEDs DT6 and DT7 and their resistors etc. got moved
Is it possible to get the (older) CAD files for our board-revision?
Manuel
Hello Manuel,
Please find attached the ZIP file for the STEP of X18-Controller-V1.2 and for the entire inverter assembly. Let me know if there's anything else you need.
Drew
Hello Drew,
thanks for your reply. These are the files I was looking for. 👍️
