Silicon positions within CAB011M12FM3 module
Matt
Contributor Level 2
To check/verify the thermal modelling of a new inverter design, I plan to measure the Mosfet module's case/base temperature directly under the sections of silicon within the device (hottest parts of base).
Please can you provide a sketch / photo showing where the silicon is located on the base plate? This would be a great help to allow me to position the thermocouples in the right locations.
Best regards
Matt
Hi Matt, please see the attached drawing for die center locations. Let us know if you need any clarification.
Thanks, that looks perfect.
Matt
