Silicon positions within CAB011M12FM3 module
Matt
Matt Contributor Level 2
edited August 2023 in Module Products
To check/verify the thermal modelling of a new inverter design, I plan to measure the Mosfet module's case/base temperature directly under the sections of silicon within the device (hottest parts of base).
Please can you provide a sketch / photo showing where the silicon is located on the base plate? This would be a great help to allow me to position the thermocouples in the right locations.
Best regards
Matt
  • ARStorment
    ARStorment Wolfspeed Employee - Contributor Level 1
    Hi Matt, please see the attached drawing for die center locations. Let us know if you need any clarification.
  • Matt
    Thanks, that looks perfect.
    Matt
