mounting CBB021M12FM3 with PCB
Dalija
Dalija Contributor Level 1
edited January 2025 in Module Products
As the current rating of CBB021M12FM3 is 48amp, while mounting the module with PCB a maximum of 48amp current will flow through the PCB also. So can a PCB handle this much of current? Also what type of pin should be connected in the PCB to takeout the terminals of CBB021M12FM3 to connect with the external circuit?
