Tpmax as a pulse rating
MattO
MattO Contributor Level 1
edited November 2023 in Module Products
IN the datasheet for CAS530 module the pulse drain current is specified with Tpmax limited by Tvjmax. What pulse length is this that the current has been specified?
  • PaulKanatzar
    PaulKanatzar Wolfspeed Employee - Contributor Level 2
    Matt,
    Figure 17 in the DS can be used to estimate the heating and determine the pulse length. That said the LTSpice models we have available are very good and can help to estimate temperature rise for a given pulse current.
    LTSpice Models (here).
    Paul Kanatzar
  • MattO
    Thanks Paul
    I had looked at the above and the spice model. The spice model looked a bit too good to be true!
    Thanks for the reply
    MAtt
