NTC measurement on the CAB450M12XM3
naman
Contributor Level 1
We plan on using the NTC temperature measurement on the CAB450M12XM3 for thermal monitoring and derating in our application.
Is there a way to relate the NTC temperature to the die or the case temperature? We have done some load profile simulations using the LTspice FET and thermal models. We have also run some simulations using the available Cauer network parameters, but are not sure how we can connect these results to the actual temperature measurement from the NTC.
Any help would be greatly appreciated!
