Low VF at low current data
Olm
Olm Contributor Level 1
edited August 17 in Discrete Products
Dear forum members.
Is there forward voltage VS current graphs at X temperature available for low current values say 1A to 100mA
for example on a C6D08065Q?
Also does the general silicon diode trick of using a larger die device, (much higher current rated than actual usage) applies in obtaining a lower forward voltage?
Thank you
  • ChadF
    ChadF Wolfspeed Admin - Contributor Level 2
    Hello Olm,
    Here is a graph showing the Foward Voltage vs Foward Current for the C6D08065Q.
    Please reach out if you have any more questions in the future.
    Best,
    Chad F.
  • Olm
    Hi Chad,
    Thank you very much for the graph, its exactly what we wanted.
    Regards
    Olm
