Thermal resistance data for CPM2 and CPW4 Power Mosfets and Diodes
ravipatel422
ravipatel422 Contributor Level 1
edited September 2022 in Bare Die Products
Hello, I wanted to see if there were thermal resistance values for these four parts:
CPM2-1200-0040B
CPM2-1200-0080B
CPW4-1200-S005B
CPW4-1200-S002B
Thanks, Ravi
    Hello Ravi,
    Thermal resistance between the junction and any other point depends on how the die is attached to that point. For example, Rth, jc for discrete packages is the thermal resistance from the junction to case depends on the die attachment to the case of the discrete package.
    For all the die products you mentioned, since they are not packaged or attached to anything (are available as die), they do not have thermal impedance specification. The thermal impedance will depend on how you choose to use them in your application.
  • ravipatel422
    Thank you
