Setup of thermal cycling testing
MinC
Wolfspeed Employee - Contributor Level 2
Hi Wolfspeed
Got one question from customer for the setup of thermal cycling testing in qualification & reliability report. is this devices soldered on the PCB or just a bare device only?
The reason for this question is customer is doing one evaluation for the mechanical stress to plastic body during the high/low temperature cycling testing. it will be great if you can provide Coefficient of thermal expansion, material yield strength, Young's modulus and Poisson ratio for our leadframe(footprint).
Thanks.
Mason
Hi Mason,
We just leave the discrete in a tray & they go through cycling.
Jianwen
Hi Jianwen
It is clear, thanks a lot for your answer.
Mason,
You are welcome. I close this case for now.
Jianwen
