Setup of thermal cycling testing
MinC
MinC Wolfspeed Employee - Contributor Level 2
edited October 2022 in Discrete Products
Hi Wolfspeed
Got one question from customer for the setup of thermal cycling testing in qualification & reliability report. is this devices soldered on the PCB or just a bare device only?
The reason for this question is customer is doing one evaluation for the mechanical stress to plastic body during the high/low temperature cycling testing. it will be great if you can provide Coefficient of thermal expansion, material yield strength, Young's modulus and Poisson ratio for our leadframe(footprint).
Thanks.
Mason
  • jshao
    jshao Wolfspeed Employee - Contributor Level 2
    Hi Mason,
    We just leave the discrete in a tray & they go through cycling.
    Jianwen
  • MinC
    Hi Jianwen
    It is clear, thanks a lot for your answer.
  • jshao
    Mason,
    You are welcome. I close this case for now.
    Jianwen
